Introduction
Basic concepts
Controller input
Radio communication
Durability
Basic usage
Getting started
  • Power it on by pressing the button
  • Wait until the green LED shows that a bias has been taken
  • Connect to the quadcopter using the computer application (make sure you have the correct channel set)
  • The red LED will now start flashing indicating that the radio communication is working
  • Fly around :)
Charging
LED indications
When USB is connected:
  • Charging: Green LED blinking at 1 Hz
  • Fully charged: Greed LED steady lit
When USB is not connected:
  • No sensor bias taken: Green LED blinking at 2 Hz
  • Sensor bias taken: Greed LED blinking at 0.5s ON 1.5s OFF
  • Radio communication: Red LED blinks for every packet received. When the red LED starts blinking slower this indicates that the radio reception is getting bad
  • Charging needed: Red LED steadily lit
projects/crazyflie/userguide/index.1331128413.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
