Introduction
What do you need for flying
Basic concepts
Controller input
Radio communication
Durability
Basic usage
Getting started
  • Power it on by pressing the power button.
  • Wait until the green LED shows that a bias has been taken
  • The red LED will now start flashing indicating that the radio communication is working
  • Fly around :)
  • When the red LED is continiously lit or/and the copter becomes uncontrollable the battery is low. Recharge and start over.
Charging
LED indications
When USB is connected:
  • Charging: Green LED blinking at 1 Hz
  • Fully charged: Greed LED steady lit
When USB is not connected:
  • No sensor bias taken: Green LED flashing at 0.75 Hz
  • Sensor bias taken: Greed LED flashing at 2Hz
  • Radio communication: Red LED blinks for every packet received. When the red LED starts blinking slower this indicates that the radio reception is getting bad
  • Charging needed: Red LED steadily lit
projects/crazyflie/userguide/index.1332154062.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
