Introduction
What do you need for flying
Basic concepts
Controller input
Radio communication
Durability
Basic usage
Getting started
  • Power it on by pressing the power button.
  • Wait until the green LED shows that a bias has been taken
  • The red LED will now start flashing indicating that the radio communication is working
  • Fly around :)
  • When the red LED is continiously lit or/and the copter becomes uncontrollable the battery is low. Recharge and start over.
The Crazyflie
  1. Red LED - Shows radio activity and charge status
  2. Green LED - Shows calibration and charge status
LED indications
During startup
  • Green LED
    • Tests passed 5 quick flashes
  • Red LED
    • Tests failed 5 quick flashes
When USB is connected:
  • Green LED
  • Red LED
When USB is not connected:
  • Green LED
  • Red LED
The USB Radio dongle
  1. USB - Connect to computer
projects/crazyflie/userguide/index.1347451001.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
