Introduction
What do you need for flying
Basic concepts
Controller input
Radio communication
Durability
Basic usage
Getting started
  • Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass.
  • Wait until the red LED shows that a bias has been taken
  • Fly around :)
The Crazyflie
LED indications
During startup
  • Green LED
  • Red LED
When USB is connected:
  • Green LED
  • Red LED
When USB is not connected:
  • Green LED
  • Red LED
The USB Radio dongle
  1. USB - Connect to computer
projects/crazyflie/userguide/index.1347452183.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
