The Crazyflie has 4 different controls: Pitch, roll, yaw and thrust. Changing the pitch and roll will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tiling the quadcopter forward will make it go forward and the same applies for every other direction.
During startup
When USB is connected:
When USB is not connected:
