Introduction
What do you need for flying
Basic concepts
Flying
The Crazyflie has 4 different controls: Pitch, roll, yaw and thrust. Changing the pitch and roll will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tiling the quadcopter forward will make it go forward and the same applies for every other direction.
Radio communication
Durability
Basic usage
Getting started
  • Wait until the red LED shows that the sensors are calibrated.
  • Fly around :)
The Crazyflie
LED indications
During startup
  • Green LED
  • Red LED
When USB is connected:
  • Green LED
  • Red LED
When USB is not connected:
  • Green LED
  • Red LED
The USB Radio dongle
  1. USB - Connect to computer
projects/crazyflie/userguide/index.1366628431.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
