Introduction
What do you need for flying
Basic concepts
Flying
Radio communication
Durability
Basic usage
Getting started
  • Fly around :)
The Crazyflie
LED indications
During startup
  • Green LED
  • Red LED
When USB is connected:
  • Green LED
  • Red LED
When USB is not connected:
  • Green LED
  • Red LED
Firmware behaviour
All these behaviours can be compile time configured. In the future they might as well be able to set at runtime using the Crazyflie client.
  • Radio communication lost
    • If the Crazyflie hasn't revieved any commander package within 0.5s it will try to level itself. The client sends out 50 control packets per second so 25 consecutive packages must have been lost
    • If the Crazyflie hasn't revieved any commander package within 2s it will turn of the all motors.
  • Inactivity shutdown
    • If the Crazyflie hasn't revieved any commander package within 5min it will automatically shut down.
The USB Radio dongle
  1. USB - Connect to computer
projects/crazyflie/userguide/index.1366630005.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
