Introduction
What do you need for flying
Basic concepts
Flying
Radio communication
Durability
Basic usage
Getting started
  • Fly around :)
The Crazyflie
LED indications
During startup
  • Green LED
  • Red LED
When USB is connected:
  • Green LED
  • Red LED
When USB is not connected:
  • Green LED
  • Red LED
Firmware behaviour
  • Radio communication lost
    • If the Crazyflie hasn't revieved any commander package within 0.5s it will try to level itself. The client sends out 100 control packets per second so 50 consecutive packages must have been lost
    • If the Crazyflie hasn't revieved any commander package within 2s it will turn off the all motors.
  • Inactivity shutdown
    • If the Crazyflie hasn't revieved any commander package within 5min it will automatically shut down.
The USB Radio dongle
  1. USB - Connect to computer
projects/crazyflie/userguide/index.1367226556.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
