Introduction
What do you need for flying
Basic concepts
Flying
[pitch,roll & foward]
Radio communication
Durability
Basic usage
Getting started
  • Power it on by pressing the side-mounted push-button
  • Fly around :)
The Crazyflie
  5. Power push-button - Push button to switch the Crazyflie on/off (Note that this is a push button, not a sliding button)
LED indications
When the Crazyflie is powered the two blue LEDs will be lit up and the red/gren LED will blink shortly indicating that the bootloader is executing. After this the firmware will start up.
During firmware startup:
  • Green LED
  • Red LED
When USB is connected:
  • Green LED
  • Red LED
When USB is not connected:
  • Green LED
  • Red LED
Firmware behaviour
  • Radio communication lost
  • Inactivity shutdown
The USB Radio dongle
  1. USB - Connect to computer
projects/crazyflie/userguide/index.1370323865.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
