projects:crazyflie:userguide:tips_and_tricks
Maximizing performance
Balancing propellers
Centre the battery weight
Getting the centre of mass(CoM) in the centre of the Crazyflie will improve the performance as it means the motors will be equally powered when hovering on one spot. That will give maximum control head room for the stabilization and best efficiency. So when you attach the battery do you best to get the weight centred.
Flying
Keeping your orientation
i.imgur.com_qpff3eh.jpg Your copter is facing forward when both the red and green LED are doing so. However, that might be a bit difficult to determine, especially if you are looking at your copter from below (since it's flying higher than your heade). To compensate for that you might want to mark the motor arm of M1 with some colored tape.
projects/crazyflie/userguide/tips_and_tricks.1368092010.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
