Getting the centre of mass(CoM) in the centre of the Crazyflie will improve the performance as it means the motors will be equally powered when hovering on one spot. That will give maximum control head room for the stabilization and best efficiency. So when you attach the battery do you best to get the weight centred.
Your copter is facing forward when both the red and green LED are doing so. However, that might be a bit difficult to determine, especially if you are looking at your copter from below (since it's flying higher than your heade). To compensate for that you might want to mark the motor arm of M1 with some colored tape.
The Crazyflie tries to hold its yaw orientation (rotation) steady based on feedback from its gyro. The orientation it's in when starting up is the one it will try to hold (unless changed via yaw inputs), so power it on in the orientation you want to fly it in. For beginners, that's almost always facing the same direction as you are, so that your pitch/roll joystick inputs line up with the physical direction the Crazyflie moves in. So, put it on the ground with the power switch in the front right corner and turn it on.
After tumbling, the Crazyflie may have a different idea of its orientation than before, since its yaw readout is relative and not absolute. This will likely result in the Crazyflie rotating as soon as it lifts off again. To fix this, reboot it in the correct orientation, or nudge the yaw axis left/right with quick hops on the thrust until it's in the right orientation before you try to steer again.
