This is probably due to a bad radio-connection (using same channel as WiFi?) or it can be due to that the Crazyflie has been pluged/unplugged to the charger as this causes the radio chip to hang (intended to be fixed in SW soon).
If the linkspeed is set to 2Mbit switch it to 250Kbps. This will normally increase/stabilize the radio reception. Since there are other devices (link WiFi) that might run on the same 2.4GHz channel try switching to a different channel for the quadcopter.
