This is probably due to a bad radio-connection (using same channel as WiFi?).
If the linkspeed is set to 2Mbit switch it to 250Kbps. This will normally increase/stabilize the radio reception. Since there are other devices (link WiFi) that might run on the same 2.4GHz channel try switching to a different channel for the quadcopter.
