projects:crazyflie:userguide:troubleshooting
Intro
Troubleshooting
This is probably due to a bad radio-connection (using same channel as WiFi?).
When I try to take off there seems to be no lift on one/or more motors?
The radio reception is bad and/or I get a lot of Too many packages lost messages?
If there are other 2.4GHz devices (WiFi, Bluetooth, etc.) around there might be running on the same channel so try switching it in the bootloader configuration block. You can also try adjusting the radio bandwidth. If you set it to 250kbit/s you will get good range outside but inside the reception/range might become worse. Since the rate is lower the data spends longer time in the air which increases the probability of interference. Changing the speed to 1Mbit/s or 2Mbit/s will give better results under these circumstances.
The radio connection is lost after a couple of meter no matter of the channel or datarate?
I have broken motors/propellers/mounts can I get spare parts?
I'm having strange problems with the sensor test not passing/motors not spinning/horizon not moving when connected?
Try to flash the latest firmware using the instructions here and firmware here.
The picture shows the console tab with no errors but when you have an error it might say e.g MPU6050: Self test acc Y [FAIL]. low: 0.300000, high: 0.949999, measured: 0.0. This example means that the accelerometer Y axis didn't pass the self test and is probably defective. It is possible to get this error also if the Crazyflie is moved to much during the self test so try putting it on a sable surface before you power it on.
Another thing to try, if you get an accelerometer self test error with measured value 0.0, is to tap/bang it on the sides. E.g. use a table edge to tap/bangit against, and tap/bang the rounded corners of the PCB (where the LEDs are). This could in theory release the accelerometer lock-up. If you managed to fix it this way please let us know as well because it is just theory now.
projects/crazyflie/userguide/troubleshooting.1369916528.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
