Overview
How to get flying
  • Start up the application
  • Press Scan
  • When the handshake is done you can start flying the Crazyflie. Remember the most tricky part is the thrust so start out easy…
Main UI
    • Address: The address to scan for. If you didn't change this in the configuration, then leave the default of 0xE7E7E7E7E7
    • Auto Reconnect: Try to automatically reconnect when connection is lost.
  5. The selected and used input interface
Functionality
Firmware upgrade
  • For Crazyflie 2.0 hold the button for about 3 seconds when turning it on until the blue LED M2 starts to blink to get into bootloader mode. If a wrong nRF51 firmware has been flashed you might have to start from an un-powered state. Then hold the button and connect power.
  • Press “Program” and wait
Firmware configuration
  • Radio channel Can be set to anything between 0 and 125, correspond to a frequency from 2400MHz to 2525MHz. In most countries channel 0 to 80 is OK to use but this should be checked with you local regulations. If using 2M datarate, the copter channels should be 2 apart (2MHz).
Crazyflie 1.0 Crazyflie 2.0
Logging
Flight settings
Input devices
Creating new mappings
Follow the instructions to detect the axis or button that you would like to map to the functionality. If you would like to map the functionality to two axis (like right/left sholder-button) then select Combined axis detection and follow the instructions.
Selecting device
Tabs
Flightcontrol
  9. Horizon indicator
Plotter
Parameters
Log blocks
  1. Fields
    • ID: Block id in Crazyflie
    • Name: Block name in client
Timestamp,pm.vbat
9103,3.74252200127
10103,3.74252200127
11103,3.74252200127
12103,3.74252200127
13103,3.74252200127
Console
Loco Positioning
To setup the LPS anchor system mode (TWR or TDoA), see the Configure LPS positioning mode wirelessly documentation.
Position estimate mode
Displays the configured anchor positions and the estimated position of the Crazyflie. Can be used to make sure the system is set up correctly and that the estimated position is reasonable.
  1. Plot for X/Y (top view) showing anchors and Crazyflie
  2. Plot for X/Z showing anchors and Crazyflie
  3. Plot for Y/Z showing anchors and Crazyflie
  4. Sets the graph mode
    • Position estimate - Normal viewing mode
    • Anchor identification - Enhanced mode where anchor id and marker becomes larger when Crazyflie is closer
  5. Indicates if anchors are communicating with Crazyflie (i.e anchors are up and running)
  6. Fit and center all data in graphs
  7. Used to set anchor positions (see below)
When setting the anchor position there's three colors to indicate the status:
  • White - No position exists for this anchor (i.e the position has not been read yet)
  • Red - Position has been read from the anchor and it differs from the currently shown value in the input box
  • Green - Position has been read from the anchor and it is the same as the currently shown value in the input box
The positions of the anchors is continuously read in the background and as positions comes in or input box values changes the colors will be set accordingly. There's also two buttons used for the settings:
  • Get from anchors - Fills the input boxes with the positions read from the anchors
  • Write to anchors - Writes the currently shown values in the input boxes to the anchors. In order to check that the write has been successful wait about 10s and all the fields should turn green as the positions are read back. If some of the fields are still red, try pressing the button again.
Anchor identification mode
  5. Current system mode indication. The system must be in TWR mode for the anchor identification mode to be available.
ZMQ backends
doc/crazyflie/client/pycfclient/index.1513699765.txt.gz · Last modified: 2017-12-19 17:09 by arnaud
