projects:crazyflie:crtp:log
Logging
For more information on how to use this and how this is implemented have a look here.
State machine
Communication protocol
Port Channel Function
1 0 Table of content access
1 1 Log control
1 2 Log data
TOC command byte Command Operation
0 GET_ITEM Get an item from the TOC
1 GET_INFO Get information about the TOC and the LOG subsystem implementation
Get TOC item
Request (PC to Copter):
        | GET_ITEM (0) | ID |
Length         1         1
Answer (Copter to PC):
        | GET_ITEM (0) | ID |                                        If index out of range
        | GET_ITEM (0) | ID | Type |   Group    |     Name     |     If returning Item
Length        1          1     1    < Null terminated strings >
Byte Request fields Content
0 GET_ITEM At 0 for GET_ITEM operation
1 ID ID of the item to be retrieved. The variables are numbered from 0 to LOG_LEN (see GET_INFO command)
Byte Answer fields Content
0 GET_ITEM 0 for GET_ITEM operation
1 ID ID of the item returned
2 Type Variable type of the element. See variable types list
3.. Group Null-terminated string containing variable group
.. Name Null-terminated string containing the variable name
Get Info
        | GET_INFO (1) |
Length         1
        | GET_INFO (1) | LOG_LEN | LOG_CRC |  LOG_MAX_PACKET | LOG_MAX_OPS |
Length        1             1         4             1               1
0 GET_INFO At 1 for GET_INFO operation
0 GET_INFO 1 for GET_INFO operation
1 LOG_LEN Number of log items contained in the log table of content
2 LOG_CRC CRC values of the log TOC memory content. This is a fingerprint of the copter build that can be used to cache the TOC
6 LOG_MAX_PACKET Maximum number of log packets that can be programmed in the copter
7 LOG_MAX_OPS Maximum number of operation programmable in the copter. An operation is one log variable retrieval programming
Log control
Control command byte Command Operation
0 CREATE_BLOCK Create a new log block
1 APPEND_BLOCK Append variables to an existing block
2 DELETE_BLOCK Delete log block
3 START_BLOCK Enable log block transmition
4 STOP_BLOCK Disable log block transmition
Create block
Append variable to block
Delete block
Start block
Stop block
Log data
The log data channel is used by the copter to send the log blocks at the programmed rate. The packet format is
        | BLOC_ID | TIME_STAMP | LOG VARIABLE VALUES |
Length        1          3           0 to 28
0 BLOCK_ID ID of the block
1 ID Timestamp in ms from the copter startup as a little-endian 3 bytes integer
4.. Log variable values Packed log values in little endian format
projects/crazyflie/crtp/log.1363768355.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
