projects:crazyflie2:index
Crazyflie 2.0
The Crazyflie 2.0 is a versatile flying development platform that weighs only 27g and fits in the palm of your hand. Its advanced functionality makes it ideal for developers and its Bluetooth low energy (LE) capability makes it easy to fly from mobile devices. With its small size and weight, it's ideal for indoor use, but can just as easily hover above your house as it can hover under your dining room table. Designed as a solderless kit, the Crazyflie 2.0 is quickly assembled by simply attaching the motors to the circuit-board frame, then it's ready to fly.
Before using the product please read the safety instructions.
Features
  • Durable design
  • Easy assembly and no soldering required
  • Supports expansion boards with automatic detection
  • Supports flying from iOS and Android with Bluetooth LE support as well as from Windows/MacOSX/Linux with the Crazyradio or Crazyradio PA
  • Tested to above 1 km radio range line-of-sight (LOS) with Crazyradio PA
  • Wireless firmware update
  • On-board charging via standard uUSB
  • Dual-MCU architecture with dedicated radio/power management SoC for advanced applications
  • Real-time logging, graphing, and setting of variables as well as full access to the available expansion boards with use of a Crazyradio or Crazyradio PA and a personal computer
Have a look at the full list of specifications.
Using
  • Assembly instructions: Image and video showing how to assemble your Crazyflie 2.0. Read this before you start assembly!
  • Userguide: User guide showing the different parts of your Crazyflie 2.0, what the LED indications mean and how to get started using it
  • Upgrading/flashing: How do upgrade/flash new firmware
  • iOS userguide: Information and userguide for the iOS app used for flying from iPhone and iPad
  • Android user guide: Information, userguide and list of compatible devices for the Android app used for flying
  • Crazyflie 2.0 serial: How to get the Crazyflie 2.0 serial on different platforms
  • FAQ: Frequently Asked Questions
Development
Expansion boards
Electronics
projects/crazyflie2/index.1444660629.txt.gz · Last modified: 2015-10-12 16:37 by macke
